Leaving boat sit questions
Results 1 to 2 of 2
    Young & Dumb FrederickFTW's Avatar
    Apr 2012
    East Brady Pa
    Default Leaving boat sit questions
    I recently blew a head gasket (what i'm guessing). Oil looked like chocolate milk. The carbs are leaking and need rebuilt. It's been 18 years since the motor was last rebuilt. So I plan on just having the motor rebuilt here this winter, until then I'm going to leave the boat in the garage. Naturally I drained the milky oil out and put new in. I haven't started the motor since I changed the oil. Beings that the boat will be sitting should I fire her up for a min let the oil pump threw? My concern is, could it possibly create some rust? Should I do anything else?? Thanks!!!!
    What I'm working with
    corona calif
    Default Blown head gasket
    Quote Originally Posted by FrederickFTW View Post
    Have you pulled spark plugs to confirm your guess if it is in fact a head gasket. There is certianlly other area's that can put water in the oil. Run a compression test to verify.
