Boat...on the rocks
Results 1 to 13 of 13
Boat...on the rocks
    Default Boat...on the rocks
    So I manged to put my 81 Eliminator Sprint on the rocks during the last outing. Carboration issues stalled my motor and I had no steering and ended up on the rocks. Was able to pull it off and float away.
    There are some good 1/8" to (less than) 1/4" deep, 6-8 foot long gashes in on the keel area (starting right before the intake) and I'm looking for some advise as to how best to make the repairs. The bottom was pristine before this happened.
    corona calif
    I believe I saw this on the hot boat sight mostly deep gouges and scratches. Glass, minimal filler. I beleive it is an Eliminator sprint so the bottom is already pretty straight. The boat could be regelled but after the work has been completed speed coat is always an option. I not sure where you live so let me know and I might be able to refer you to a shop in your area. Greg
    I posted some pictures on Banderlog. Here are two links. One is tot he pictures of the boat on the rocks the other is of teh gouges themselves. I live in Turlock, CA (near Modesto). Thanks for the input. I really appreciate it.
    http://www.banderlog.com/phpBB2/view...er=asc&start=0
    http://www.banderlog.com/phpBB2/view...=5274&start=15
    Silverdale, Washington
    I am by no means an expert or will ever hope to possess the knowledge that Greg and the rest of the folks on this board have, but, here's a thought based on my limited experiance.
    On my boat I had many of these (though not quite as deep) and the direction I went with is to clean them out well and lay it back a bit, wipe the gouges out with Acetone and then wetted it out with some resin/hardener. I then followed that with some resin/hardener with some colodial silica mixed in. I'm very happy with the results.
    For what it worth, and again, I'm no expert........good luck.......john
    ROC
    ROC is offline
    Extraordinarily good ROC's Avatar
    LOL, at first I thought this thread was about my boat, named "ON THE ROCKS"
    Some of you know the story.
    Greg- Can you reccomend a glass shop in the Modesto-Stockton area? How about a motor builder? Upholstery?
    River Rat, check with "Smooth as Glass". I believe they are in Riverbank. The owner used to post as "Washed Ashore" on HB. I have heard nothing but good things about them.
    Just checked the members list. He posts here as "Washed Ashore" also.
    Senior Member zipper's Avatar
    Livermore,Ca
    Engine-Joey Grose
    TEN THIRTY ONE RCB19's Avatar
    Thumbs up
    Quote Originally Posted by zipper View Post
    Engine-Joey Grose
    RCB
    Engine-Joey Grose
    In Lodi, CA???
    Livermore,Ca
    Default Grose
    JOEY GROSE
    46N.HoustonLane
    Lodi,Ca95240
    209-368-8308
    Does killer work
  13. #12
    Modesto, CA
    Default upholstry
    I had my boat done at Atlas Canvas in Modesto, right next to Bob's Marine on Oakdale and Briggsmore. They did a killer job on both the upholstry work and on the floor and carpet replacement. Great price and quickly done. Less than a week. If you go by tell the Victor with the Jet boat sent you and he should hook you up.
  14. #13
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    Quote Originally Posted by River Rat View Post
    Jeff Glow
    Smooth As Glass Fiberglass Boat Repair
    2808 Patterson Rd # D
    Riverbank, CA 95367
    (209) 869-3545
    Adam Soares
    CG CUSTOMS & INTERIOR DESIGN
    582 Commerce Ct. Manteca, CA 95336
    Office: 209-823-7184 Fax: 209-823-7185
    They do great work
