On a berk pump with a split bowl what is the best oil to run?
Asstroglide!
Since it's technically for the rear of the pump, I'm gonna have to say Anal Ease![]()
2002 Ultra 21 XS
2000 Ultra 19 Shadow
Let's say I have a "friend" who filled up the bowl with oil and when he
started the engine, all the oil blew out the jet.
What does this mean?![]()
Any cheap Gear oil if fine.
No "gears" in there, just a shaft and bushings. I've run cheap thick straight wt oil also...no problem.
I was talking to Dave at Aggressor, he said that the seal doesn't work that well on the bowls for purposes of keeping water out, better to use grease.
