theres a t deck southwind tunnel jet boat that i discovered in the back yard behind our state yard.with this being said i can get it pretty cheap.my question is is this better than or as good as a the southwind tunnel dragster.the bottoms look to be the same but one has the stand off box and this t deck looks to have the standered flat transom. i have a crusader tunnel hull but the floors are so thin and rotted from leaves being stored in it that i figured if i can build the southwind for less and go as fast and shut down isnt an issue then i will try and buy it.thanks for the info justin
it should be the same bottom without the pod. but its hard to tell with out pics. some have been hacked up and changed. there is only one or two that ever came out of the original Southwind factory.
