Originally Posted by
bp298
do what greg suggested. just because someone says a bearing -should- last for 1000 hours doesn't mean it will. it -could- last for 10,000 hours, but that's not applicable to the whine you're hearing. it's a bearing with balls in it, it could have gotten wet at some point, and could be failing. if you remove the alternator belt, and still hear the whine, park the thing until it's fixed, or you can cause A LOT of damage to the pump. more damage = more money. removing the pump is a bit tedious, but pretty simple - an hour or two. but the pump would need to be completely disassembled to replace the bearing. get it to a good shop that checks -everything-, and you'll have it back together in short order.
