Originally Posted by
greg shoemaker
Beleive it or not but the Carrera and the Omega in those days were built within a 100 yards of each other on Sunshine Way in Anaheim Ca. The decks are slightly different but the bottoms i beleive are very similar. Your research is correct to move you pump out that far will create problems. When you see boats with the handhole cover outside of the boat you will also notice the transom is completely flat on the Carrera and the Omega both have a 12 degree angled transom so the handhole appears to be farther in but actually is in the same spot as the flat transom boat. I'm was wondering if you had considered the American Turbine panther conversion?
