CI
Results 1 to 13 of 13
CI
    Senior Member Master Sergeant's Avatar
    Sacramento
    Default CI
    I have heard from more than 1 person that jet boats like engines in the general size of 500CI and that anything much larger than that can make the boat go slower? can this be true? I would think the bigger, the better.
    Quote Originally Posted by Master Sergeant View Post
    sounds like those guys are scared to go fast.
    corona calif
    Default Cubic inches
    Bigger is better. Right now it is not uncommon for us to build a larger cubic inch engine with low compression. 566, 572, and a 598 all come to mind.
    Sacramento
    Why low compression? How low?
    spokane, WA
    My 565 is almost out of the machine shop, I sure hope the daytona will like it!!
    Travis
    I like my women like I like my boats......Fast and ready to get wet at all times!!
    corona calif
    Default Top
    We build the engines with low compression so that you can use 91 octane fuel.
    I'm kind of curious to know who told you this. Can I assume it is something you heard at CFW on Father's Day?
    Sacramento
    Some guys in Arizona. It makes sense on a larger scale. Eventually the size of an engine would limit rpm.
    MAMA TRIED BENSE's Avatar
    SOMEWHERE BETWEEN HEAVEN & HELL
    Only reason i see to limiting CI size is if you are planning on running a class that calls for limited CI.
    FILTHY FEW
    spokane, WA
    A guy we race with runs a Sonny's semi hemi in on 09 GTO body, 892 CI and he goes through the lights at 7600rpm.... It makes 2180 Naturaly aspirated! We ran an all aluminum 632 from Steve Schmidt in the dragster and would shift it at 7300 and through the lights at 7500...
    Engine size is not going to limit the rpm like you think, how much rpm are you looking for?
    Travis
    Sacramento
    Quote Originally Posted by TwinTurbo540 View Post
    Travis
    Not much, my 489 is turning my A impeller at 6K so even with the extra HP the RPMs would not be high.
  13. #12
    DJD
    DJD is offline
    6TH STREET MAFIA PRES. DJD's Avatar
    Closer to the river than you!
    Different strokes for different folks. A good friend of mine used to tell me that a chainsaw stlye motor will ET better than a long stroke deal just cause of the imediate rpm's at the hit. Seems like theres alot of different setups and motor combos that run really good now days.
  14. #13
    My 540 tt spins a aaa 4900@ 104mph
