Mach 22 jet boat
Results 1 to 5 of 5
Mach 22 jet boat
    Aug 2010
    El Cajon
    Default Mach 22 jet boat
    Have you guys Set a pump in a Mach 22?
    I am thinking about buying a hull from Kevin, he bought Daves mold.
    What would it take for you to properly set it up as Kevin nor Dave has not done a jet drive in this model?
    Would the mold have to be modified?
    Thanks, Gordon
    corona calif
    Default Mach 22
    Do you have any pictures of this boat? If so can you send them to me or post them. There was not a lot of these boats built so it would be helpful to see a boat or atleast photo's.
    Aug 2010
    El Cajon
    I'll see if Kevin has any photos of the transom...I'm assuming that's what you need?
    B&G
    B&G is offline
    Senior Member B&G's Avatar
    Feb 2009
    Yucaipa, CA.
    Greg if you need to check one out, I have an 07 with an outboard on it. Don't know if it would help?
    Corey
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    The center pod is too shallow and narrow, there would have to be a decent amount of work involved in order to get one to work IMO.
    Definitely possible though!
    I think if Kevin at KMG would tool up a jet bottom he would most likely sell the shit out of em!
