low profile intakes on gullwings?
Page 1 of 2 12 LastLast
Results 1 to 14 of 15
    Default low profile intakes on gullwings?
    greg, how does a low profile intake help gullwings fly so high? is it just basically lower the entire pump down closer to keel level or is it the intake throat angle? i've never seen a low profile intake in person and its got me wondering about em. thanx tom e.
    Senior Member snake321's Avatar
    Middletown, Connecticut, United States
    YOU LIE!!!!!!!!!!!
    Quote Originally Posted by Ultra26 # 1 View Post
    I've been known to be a jackass a time or two.
    415 M3
    So Ca
    Quote Originally Posted by snake321 View Post
    Is this intended to be usefull information pertaining to the low profile intake question, or spam?
    415 M3
    So Ca
    Ok, I see it now. He just has'nt seen a low profile intake before. Nevermind, I'm drinking.
    Quote Originally Posted by gunslinger View Post
    me too i've seen them before , just not in person just wondering what benefits they provide. gonna be doin my floor this winter and while i had the intake out, figured i could upgrade if it was worth the $$$$$
    UMPBA.ORG sleekcrafter's Avatar
    Generally you get an extra degree of pump angle, and the fact the pump is much closer to the water. Shorter entry, less water lift to the pump, all help in efficiency. You can run less aggressive hardware to get you pump loading properly, less drag = more speed. Plus the gained transom lift, allows you to be quicker, and not fly at a nose high attitude, making it not so bad on shut down. There are so many pluses to running one, why would one choose to to run one.
    corona calif
    Default low profile
    As long as I can remember the baseline setup on a gullwing has always been a 4 degree intake with various shoe combinations all which prove to be effective with proper guidance and setup. When it comes to a low profile intake there only a few that have ventured into this area of setup. Impatient pretty much sums it up lower thrust line more lift, more lift in a vee bottom can be a bad thing, I 'm not opposed to the low profile intake in a vee bottom but with todays power that can be made this can become a very flighty combination when not properly srtup.
    corona calif
    Default miatake
    Sleekcrafter is the post that gave us the info.
    thanx for the info sleek and greg i've got a dominator mb1201 intake now and it's working fine, i was just curious.
    B1 Racing cs19's Avatar
    Joe Lakamp. MPD low profile intake. 18 CP. Dialed
    B1Racing.net
    Lexington, KY
    Talking
    That's awesome!!!
    The boat is barely in the water!!! Not much drag there!
    How fast do you think he is going in that picture?
    HJ
  13. #12
    If I could get into Hot Boat I had a thread asking about the low profile intakes and I posted a picture of a berkeley and a GTH side by side.
    YOU LIE!!!!!!!!!!!
  14. #13
    corona calif
    Default Low profile
    As you can see a low profile intake in the wrong hands can be a hand full
  15. #14
    So you got yourself banned did ya.......
    They removed your picture's but here is the thread: http://www.hotboat.com/forums/showthread.php?t=171427
    Sleeper CP
