Originally Posted by
5akman
Hi,
thanks for all the info over the phone the other day regarding my Kodiak 460 going into my Alaska work skiff. Since its a new to me engine that I haven't run and its the off season and I have the engine on the stand, I'm going to take it apart to check wear/clearances. While I'm at it, I'm thinking I might add some flat top pistons to get the compression ratio up around 9:1 or better with the D3ve heads. I was also thinking a cam change at this time. For my lower speed application with the Berk AA impeller would something like the Herbert CH3n with 270/285, 215/225 at .050 and .500/.530 on 112 lobe separation work for me?
Thanks again Greg!
Lance
