Originally Posted by
loroper
Greg,
Just bought my first jet at 52 years old. Its a 1978 Condor Sprint with a 454. motor was just redone bored 30 over with a summit cam...paper says .50 lift with238/248 duration, says advertised as 0.540 lift with296/306 duration. Looks like it has stock intake. the carb is a holley 750 Dbl Pmpr. carb looks bad has broken overflow spout. My question, going to buy new carb and maybe intake. Does it need a Dbl Pmpr ? Which carb and intake combination will work Best?
My first post,too long?
Thanks for any imput
Loroper[/QUOTE
Being it has taken you 52 years to buy a jetboat lets see if we can't make it a enjoyable experience. Have you removed the intake manifold to see if it is a retangular port head or an oval port cylinder head this will make a difference when you select an intake manifold. What exhaust are you running on the boat?What inginition do you have? Once we have this info I will be able to help you with your selection.
