Thread Tools | Display Modes |
#1 |
So, I killed a battery some time ago.. Then in the process of charging it I lost the starter. Starter was finally fixed but now she wont crank. Assumed crap battery so i just picked up a 27 series blue top Optima...
here is what she does... when i first installed the new Optima battery i jumped the ground wire off the starter to a hot lead to see if she would turn over. (Success ) I then go up to the dash and insert key and move to AUX. power comes on in the dash (Success) I then flip it over to start and i get one Click and the whole SOB dies and no more juice.. (Failure) I then go back to the back and try to jump the ground wire off the starter to a hot lead and nada. (Failure).. Since i could jump it before and now can not does that sound like a faulty ground? replaceing the pos and neg cables and the ground is easy enough.. Just wanted an opinion before i started grasping at straws. |
#2 | |
Platinum Member
Quote:
__________________
If you ain't the lead dog, the view is always the same..
#3 |
JetBoat Marine Parts&Svc
High resistance, dirty or corroded terminals and or ends sounds like your on the right track , does this system run a "helper" solenoid? , doesn't take much to tick the guages, but a solid 12v signal to bump the solenoid Pictures?
__________________
#4 | |
Quote:
X2 on that helper solenoid...i run a motorcycle starter solenoid mounted at the starter....takes very little current to trigger it...i.e. 40 FEET of 20 gauge wire will kick it |
#5 | |
Platinum Member
Quote:
__________________
#6 | |
Quote:
#7 |
Are you trying to ground the battery to the block with a nice coat of paint on the block? Although pretty, paint is a lousy conductor and it is a common mistake. Nice shiny metal under the ground lead.......Also, the key switch CAN wear out and the "start" position fails to trigger the solenoid through 14/16 ga wire. You might consider a heavy duty starter button and some heavier wire, 12ga, into, and out of, the button to the solenoid...........Ray
__________________
ZERO tolerance for illegal entry......ZERO chance for amnesty, ever...... LOUD BOATS SAVE LIVES Driving a slow boat fast, is a lot more fun than driving a fast boat slow....... |
#8 | |
Quote:
You know what.. I did just repaint that bellhousing and i know i did not remove the paint underneath that ground... ![]() Its allways the simple stuff that trips me up.. Thanks guys !!! |
#9 |
I cleaned the ground and nada.. I cleaned the pos and neg batt/cable terminals and it sprung to life.. amazing what a little bit of corrosion can do to stop electricity.
#10 |
Horsepower sells Engines
so all better now then?
__________________
"Horsepower sells Engines but torque wins races." "winners never quit, quitters never win those who never win and never quit are idiots" "if at first you don't succeed redefine success" "why is there never time to do it right, but there is aways time to do it twice" ![]() |
#11 |
Yea man.. my eletrical problem is no more.. For now
| Digg This Thread |
| Thread Tools | |
| Display Modes | |
