Miller Rail kits install
Page 1 of 2 12 LastLast
Results 1 to 14 of 16
    Default Miller Rail kits install
    This is a great "Canvas" to display one of our new JBP Rail kit installs, please follow along and feel free to ask questions , Thanks Tommy (that guy) for the opportunity to do this job !
    out with the engine ;
    out with the 4 points
    Found some slightly uneven stringers hmmmm? ...
    Default Repairing the uneveness
    We decided to use an epoxy faring compound to "straighten out" the inner edges of the stringers so we wouldn't distort the rails ,Josh did this using the inner rails as forms This stringers were roughed upp and masked ,epoxy applied and let cure between the stringers and aluminum rails
    The epoxy was then coated with Black pigmented resin
    Senior Member Rain Maker MN's Avatar
    Tom -
    Couple questions, my stringers are the same way....what causes the indentations?
    How stong in the fairing coupound you used? Structurally is this more of a cosmetic deal?
    Did you remove the rails before the epoxy cured or what did you do so it would stick?
    Quote Originally Posted by Rain Maker MN View Post
    Tom -
    Hi Pete how ya been , hope you Folks warm up soon ! On Tommys boat the stringers had been previously repaired , but some boats depending on the stringer glass work are simply not straight , the Idea here was to simply fill the small voids to keep from distorting the rails and yes for cosmetics as well, Josh used wax/release agent and the actual stringers as a "form" the actual rails were clamped in place and then removed after the epoxy kicked to check, smooth and gel coat . As epoxy has no real structure anything beyond a very small divot would not be acceptable. The actual product we used for faring was Interlux Tom
    Default some progress!
    Final fitting before the powder coating "our "Mock block" and mock pan is a little bulky but it works!
    Knotching/milling the plates that "run wild" over the stringers
    Redding, CA
    Looks awesome, Tom!
    Sorry I have been off-line for a while, looking out at the beach from our balcony in Hawaii!!
    (Sold the hydro, so I charged up this trip, and actually might be able to pay you guys!)
    I knew one stringer had work done before, and some of the "dents" where there from over tightening the "feet" for the 4 points by a previous owner.
    Any trouble with the starter clearances??
    Tommy
    Quote Originally Posted by ram78d10 View Post
    I've talked with numerous teachers
    all the teachers I have talked to agree
    That's their problem, they can't print money.
    Quote Originally Posted by cvxjet View Post
    I rarely meet people that are smarter than me-
    Probably reading this contemplating the Surf and sipping something with a little umbrella in it Huh!
    Well here the Pan swap some odd "Caca" in the bottom but no metal ! (looks like silly- cone) New pan is on tommorow ! Tom
    BTW Nice rods and crank !!
    Redding, CA
    I get that a lot!!
    That is an Eagle neutral balance forging and their "good" H beams with cap screws.
    Stock stroke and bore. (.030)
    The Eagle kit with SRP's was only like $1,500.00 or so.
    We will be in Frisco in the 7th, and can be at the shop on Tuesday morning, the 8th?
    Thanks again!
    Tommy
    Already miss the 310/562 2manymustangs's Avatar
    I get that a lot!!
    Thanks again!
    There will be NO living with him after that comment as evidenced above...
    Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties......... Honest Abe..........
    California
    No trouble, i relieved the rail a little to give the starter some breathin room. It probably would have cleared by a hair, but it wouldn't have left any room to work on it. I also relieved a touch for the oil filter on the opposite side, again it probably would have cleared but not by much.
    Redding, CA
    Quote Originally Posted by 2manymustangs View Post
    Hell, Deb barely puts up with Me now!!
    Quote Originally Posted by Josh@JBP View Post
    Sounds great Josh!
    Are we still on for Tuesday AM??
    Tommy
  13. #12
    Going to the powder coater tommorow AM (Sat), can't wait to see the rails and plates , Josh "massaged" the new HP/HV oil pump today and welded the new pickup on to withstand those Jet boat airborne episodes The New pan just needs to be cleaned and prepped and were on the way to reinstall ,More pics to follow Tom
  14. #13
    Were almost there Tommy Josh "spanked" that B*tch today ! Tom
    Miller Mania Today at JBP
  15. #14
    Redding, CA
    Awesome!!!!
    See You in a couple days!!
    (Got some Kona coffee and Macadamia nuts for you guys....)
    Tommy
