As a new jet boater, I fell victim to a blown engine. The previous owner had freshly rebuilt the Olds 455 in my boat and said not to touch the gate valve on the water line entering the engine. After being on the water for about 45 minutes, with no hard running of the engine, I made a half throttle launch and ended up with a busted piston and a rod ran through the cylinder wall. I've built a new engine and it hasn't seen water yet.
I have been doing some research on the water pressure issue and have found the article on Performance Jet to be the most logical solution:
Performance Jet -Jet Boat High Performance Design
Does anyone here run this setup? If so, does it work or do I need to look at some other options?
Thanks!
LinkBack URL
About LinkBacks
