Originally Posted by
goducks70
Thanks for the reply, Tom. In light of the fact that I have all the flooring removed, I do think I'll go ahead and install new foam. As before, I am still surprised that there is none present, it's was obviously never installed. I have quite a bit of trailer work to do before I can finish the floor though. After I removed the deck, I could see that the existing runners are somewhat inadequate, the hull is bowing pretty bad on each side due to the fact that there is only one 2x4 runner on each side from about the middle of the boat to the bow. I plan on lifting the boat off the trailer just enough to replace the rear and forward runners, but with 2x6. In addition, I'm going to weld up some more brackets to the trailer and add a few more runners to give the hull nice, even support. Like I said, this boat is 23' and has a BBC, so it is not exactly a featherweight! I have to replace about 4 or 5' of the stringers in the front as well. To give them a little more strength I'm going to sister both stringers up, full length, on each side, with 3/4" plywood and then go over the whole works with a few layers of fiberglass cloth. I think that the foam will more than offset this additional weight, and the added support will be worth it. I'm also going to add a few bulkheads. Originally, there were only two plywood bulkheads in the bow section that defined a recessed area in front of the seats in the cabin area, as well as one in front of the engine. This seems a little inadequate so I'll be replacing the two up front with 2x6 as well as adding a few more down the length of the hull, can't hurt, and the compartments will make pouring the foam a little easier, I've worked with that stuff before and found out the hard way that a smaller area is MUCH easier to work with than a large one! At any rate, thanks again for the input, I see that you guys are located in Atascadero, I am in the central valley,(Lemoore) maybe I'll see you at Nac this summer..!
