Originally Posted by
Frank
no previous setup. I built boat from scratch/re-cut holes for jet, paint, interior, engine, wiring, tanks. low HP, probably 350-400ish (alum heads/roller cam/dual quad/12 qt pan/bassett headers, A2 impellor) good compression, runs solid, handles good for a tunnel. certainly one of the prettier boats on the lake, no other jets or v-drives in the couple fresh water lakes in the NJ area. I shaved the jet so it puts on quite the water show - hope I don't blow off the nozzle. fairly fast, but nothing extrordinary - just sexy as hell
definitely room to move starter around with slop in mounting holes. guess I'll have to get inspection mirror and look around again.
when it turns, sounds great. when it doesn't catch, sounds like its not engaging at all - loud/obnoxious screech. never sounds tight/straining. 'cuase it works 90 percent of the time, I've ignored it. ...but since its winter
