so i got a 74 southwind 18 foot it has a 455 someone pieced together it has 403 heads on it .
I have a 455 out of a 69 toronado hooked to a 4 speed and a posi .
It smokes the tires at will . I think im going to pull it and put it into the boat
minimum you will have to buy a 10qt pan...hopefully you have 4 point engine mounts in your boat(10 qt pan will not fit if you have the three point mounts)
i have been running olds for 10 seasons now...
don't run it too much past 5000 rpm's
watch your oil pressure gauge.....
the problem you will have is all your oil will be in your valve covers at higher rpm's...........................
Excuse my curiosity but are you sure that motors from a Toronado ? as most as I can recall were front wheel drives ? if its from a FWD It would have likley may have a special oil pan , could be wrong also suspect if its the original motor its likley a 400 cu , still might be good piece Tom
Toranado pan is a little deeper. Holds about a quart more. If you have room for it. It is a step up.
its a 455 i had it apart when i got it . i put forged pistons and a cam
I put restrictors in the oil passages and its got the toro pan on it
and i opulled it from the toro myself
Probably my mistake I worked at Oldsmoble in 71 never saw one with a 4 speed but they did come with 400 or 455
1969 Oldsmobile Toronado
1969 Olds’ Toronado saw another restyle, with changes that added a longer rearend designed to visually balance the long front end. Still offered as Oldsmobile’s only front wheel drive car, the ’69 Toronado started with a base price of about $4835.00 and could be purchased with the standard 375hp motor or the 400hp 455 V8. New was a vinyl roof option, which added a more executive look.
Engine may not have been in the toronado when coupled to the 4 speed, perhaps a different car. Pay attention to oil control (pan), its much different in a jet boat than a car. And consider that the motor isn't running flat out at 5K in an average car either. Much different situation, which defines the demise of many an Oldsmobile used in jet apps in the past not properly prepared for it in terms of oil control and management.
Rex Marine Home
Rex Marine Shopping
Mike
909-592-1000
See my photo gallery at mikegeephotos.com
A tribute to the victims of 911 - Never Forget!A Tribute to our Troops (Remember Me)
Please Spay & Neuter your Pets (a video)Please adopt and learn about the huge problem of overpopulation (a video)
Please Feed a Shelter Dog (It's Free) - Your clicks can mean the difference between life and death.<<<![]()
“He who is cruel to animals becomes hard also in his dealings with men. We can judge the heart of a man by his treatment of animals.” Immanuel Kant
I always wondered?? If an Olds doesn't like the high RPMs of a jet boat why not put a large impellor in and keep the high revs down! Those motors made good TQ so they should pull a large impellor well!
WT
WFL Crew!!!
i know $400.00 for a pan sounds like alot...BUT...it is the best investment you can make on an OLDS!!!
the difference between one or two boating trips------------or many good seasons-----------
auxiliary head drain backs to the pan will work too........
as Rexone said...being in a car and being in a boat are two different animals...
before i knew about olds...i tried the same thing...IT LASTED 5 MINUTES........
i was told to run mine a quart high...10qt pan, 1 in the filter, and one high...i run a full case. have been for 10 years now. most dependable boat i have ever owned.....................
I ran a 425HP Toronado engine in my 18 foot Elim, did all the mods and that was the little engine that could! Ran the piss out of that thing and it never gave me any problems except water reversion at first, once I figured that out she was a runner.
good luck!!!!
i just hate all the bad publicity with olds...would love to hear another success story...they are far and few between...i personally have never heard of anyone getting away with a car pan and running 5000rpm's for any time...one guy last year at Mardons had a car pan on his olds. i freaked out and told him to get the bigger pan. he told me he had been out all year with the small one. assured me he runs it hard all the time. needless to say, he smoked his motor on the way back to the beach........
I would caution (in any engine not just Olds) against running the oil level high (above the windage tray). What happens is the crank picks up the oil and foams it up, resulting in loss of oil pressure. Keep the oil under the tray (whatever level that is) and things stay much happier.
Rex Marine Home
Rex Marine Shopping
Mike
909-592-1000
