i personally hate the terminal blocks. i think they are stupid, worthless, and ugly. i recently bought an eliminator that had the block setup in it. i removed it, one wire at a time, soldered, shrink wrapped, and electrical taped the whole wiring loom. IMO it is just as easy to remove wires from where they go(IE alt, starter, etc) as it is from the ugly in your face terminal block!
you don't need a wiring diagram...
all your wires are color coded...(same color on one side of your terminal block-as the other)
all you need is a plug style with as many wires as your boat(or more)...
connect the wires one at a time if you have too.....
