Originally Posted by
67weiman
So if water comes in the front and dumps out the front, wouldn't the path least resistance be out the front? I dump outta the rear. No t stat, four corner manifold. I plumber from the front to the rear, wit a t each side continue to a t to tie both aides together at the dump. Now, if the block fills with water, entering in the front, isn't more cold water going straight thru thread right back outta the dump at thefront? Head gaskets restricting flow yeah, but why wouldn't said hot spot be in the rear of the block if water enters in the front and exits in the front. Nothing forces water to the rear other than pressure correct? So if the heads have restricted flow and you are pushing water at let's say 18 lbs. Wouldn't it be beneficial to force into the rear to exit? How can it not flow across the head front to rear? Why are four corner manifold made?
