d2oe-ab vs d3ve heads
Page 1 of 2 12 LastLast
Results 1 to 14 of 18
    77 sleek. corbin5754's Avatar
    Aug 2011
    indy.
    Default d2oe-ab vs d3ve heads
    I currently have the d3ve a2a heads but saw a Set of d2oe-ab on Cl for $400 would these be a improvement for my 460 pretty much stock. Are they a direct replacement of the d3ve how much horsepower can it add.
    Anza Valley, Lost Lake, CA
    According to my dad the Police Intercepter Heads are a direct replacement for your's EXCEPT for the Rocker Arms/PushRods. D3VE Heads use a Bolt down Rocker. D2OE-AA or AB Heads use a Stud type Rocker. Change to a Stud mount Roller Rocker and Hardened PushRods and they're a bolt on(PI Heads use guide plates).
    If your D3 Heads are stock you should pick up 30-40 hp easy. More if you have performance upgrades done to your engine. Even more if you have the Heads ported, etc.
    Hope that helps you out.
    Curt
    Aug 2011
    indy.
    Ok cool I also found some dove-c heads in my area one set for 225 good to go and another set for 150 but says needs recondtioned. Dove- c is better then d3ve right would I see same HP increase with these also, and port and polish them.
    Quote Originally Posted by corbin5754 View Post
    Probably close according to RiverRacer(my dad). The D2OE Heads will flow a better stock, but the DOVE Heads will pick up compression. Ported, both will add lots of power over the D3 type.
    Curt
    Aug 2011
    indy.
    Thankyou sir
    Jul 2009
    Quote Originally Posted by Turtle View Post
    Curt
    So what kind of gain wwould you get with CJ valves in Dove c heads with port work, polish, and a better cam, say the comp xm 278 h, or the xm 288h?
    Oct 2011
    I just finished my 460 with, xm270 cam,9.7-1 cr, ported doves, oversize valves, stealth intake, 800cfm carb, made 514hp
    Oct 2011
    The doves flow really good on intake , exhaust was crap. Just put bigger exhaust valves in and you will be good.
    Jul 2009
    Quote Originally Posted by rpm0414 View Post
    That's what I was thinking of running. The 270 isn't what I had in mind. Maybe the the 280, but the 278 has the upper end I am looking for. But hey 514 hp sound great to me!
    Oct 2011
    Match the cam to impeller. Those cams would work with small impeller. I have an A impeller and even with 500 hp it will only turn max rpm of 5000rpm. Those bigger cams prob just hurt power if you aren't gonna spin it past 6000rpm
    Norco
    Thankyou sir
    Do your self a favor, and contact Paul AKA Lakesonly. He knows is Ford and even sells heads, stock, ported, cleaned up, ect, from mild to wild. You WILL get a good set of heads. He will give so so much info your head will spin.
    Made In The Shade
    Custom Window Tinting
    Jul 2009
    Quote Originally Posted by danhercules View Post
    I did, he is booked for the next 3 months, and my heads are in need of porting, blending. I got a guy local that is good with a flow. I already have the 2.25 intake, and 1.8 exhaust valves, swirl polished stainless. I just have to deside what cam. Paul,had recommend the 278h grind, and even a voodoo grind. That guy is awesome! He has a great deal for some one with dove heads.
    Aug 2011
    indy.
    These are it said he would sell um for 180 are they worth it. He said the valves look to be new.
