I have dual aluminum gas tanks in my Eliminator Sport, One of them has a pinhole leak in the bottom. The other tank has some corrosion on the bottom that looks like it could start leaking soon. Is there any way to stop this corrosion? Is there and any sealer I can use on inside of the tank. Do you think it would be safer to have somebody replace the entire bottom of the tank then seal it? Just checking my options here?
I have another question too. The tanks do not have any type of vent. I thought the fuel fills were vented but they are not. I'm surprised the boat even ran without going into vapor lock. What is the correct way of venting the fuel system if I have an enclosed engine compartment?
ry-guy
LinkBack URL
About LinkBacks
