On a properly adjusted hydraulic sbc/bbc valve, the pushrod will turn pretty easy, and using the "spin the pushrod" method maybe too tight. I feel for zero lash by "jiggling" the pushrod up and down, then 1/8 to 1/4 turn, or .060" preload, on hydraulic lifters, also works for mechanical lifters for setting lash.
Here is a way to adjust the valves by turning the crank once, factory firing order:
#1 TDC
EX 1 3 4 8
IN 1 2 5 7
#1, 180* out, or #6 TDC
EX 2 5 6 7
IN 3 4 6 8
I don't like turning the motor endless times between every valve- no oil pressure, major compression/friction, etc
Hope this helps
Daniel
Mash on it
