Pollak fuel tank selector
Page 1 of 2 12 LastLast
Results 1 to 14 of 16
    Member Mohavekid's Avatar
    Penn Valley, CAThe Sierra Foothills
    Default Pollak fuel tank selector
    I am looking for a supplier for a Pollak fuel tank selector valve like the one pictured below.
    I have checked Rex and CPPerformance with no luck.
    The Pollak website has nothing marine rated. Can anyone help?
Name:	Fuel valve.jpg
    Senior Member Johnny West's Avatar
    Winchester, CA
    They stopped making them in the late 90's.
    Anyone have an economical alternative?
    I would like to maintain the dash mounted switch if possible.
    Oct 2010
    661 So. Cal.
    check your local napa they sell those in their line.
    Senior Member h2oracer's Avatar
    Kragen has them. Not that brand. I think the one I bought was made borg warner. It's for automotive use not marine.
    Thanks guys. I'll check with NAPA.
    Senior Member Mojave85's Avatar
    Boise, Idaho
    They aren't marine approved and have a sticker right on them stating so - but I just installed one in my daughters boat anyway. NAPA should have exactly what you are needing if you can ignore the not for marine use deal.
    Senior Member FormulaZR's Avatar
    Jul 2010
    Any of you guys have a part number/price?
    If it flies, floats, or fornicates you are bound to have trouble with it.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    When I added a little power over the stock engine, upped it to around 500, the Pollak you have pictured didn't allow enough fuel to the engine. As you can see in the picture, the one I took out is a lot smaller than the Pollak I replaced it with. Oh and btw, the little one came with the boat as original and it was not marine approved probably due to the plastic fittings.
    just food for thought
    Cas, the valve pictured on the left is also a Pollack? I assume its the three port listed on their website.
    What are the extra wires on the plug for? The valve I took out only had two wires.
    Cas
    Cas is offline
    Quote Originally Posted by Mohavekid View Post
    Yes, both of them are Pollaks and I'm not sure if this one is the same one listed. As far as the wires go, looking at the picture from the top down-
    1. tank 2 sending unit
    2. fuel gauge
    3. tank 1 sending unit
    4. to switch
    5. to switch
    The switch needs to be a DPDT and the part number on the selector valve is 42-154. No, I didn't do that by memory, I needed to find the instruction sheet
    It is CG approved but I'm not sure Pollak makes this particular valve any longer. If you don't need it right away, just keep an eye on ebay as they pop up once in awhile. I think I have the old one around here that you can have for the price of shipping. It should hold you over until you find one of the bigger ones should you want to go that route.
  13. #12
    Long Beach
    These were never marine rated. It's a motor home tank selector. At least that's what they were listed as when thousands of them found their way into boats back in the day.
    The one on the left is a GREAT switch.
  14. #13
    Cas
    Cas is offline
    Quote Originally Posted by old rigger View Post
    Sure is, Thanks for finding it buried in your garage!
  15. #14
    Second Chance unpredictable27's Avatar
    Anyone got one of those selectors not being used??? The one on the left.
