anyone running a d impeller
Results 1 to 11 of 11
    Senior Member speedealer's Avatar
    Albuquerque,N.M.
    Default anyone running a d impeller
    i'm running a raceprepped mpd C imp. thinking about trying a D, any negative thoughts about running that small of an imp.
    Shell Knob, MO
    Pretty hard to give an answer without any information about what your current stats are and where you want to go from here.??????????????????????????
    B1 Racing cs19's Avatar
    Ran some really small c cuts last year with good results. What are you thinking about cutting it to. Angles and OD?
    Chris
    B1Racing.net
    Albuquerque,N.M.
    yeah i figured i should have given info. its a 18ft 300lb earl smith tunnel with an alum 500ci makes 947@8200 . boat runs 6400, eng makes 712@ 6400. looking for as much rpm gain as possible and load the pump.
    Shell Knob, MO
    Thanks, yes it should help if you start moving towards a properly prepaired D. If you are running Jack's pump and set up. I'd suggest that you ask him.
    Duane HTP
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Quote Originally Posted by speedealer View Post
    I would run a gear box with a A impeller.Casale or Owens box.
    Feb 2012
    not picking, but why would you make a motor like that for a jetboat? That RPM really doesnt make sense in a todays kinda jetboat with the technology available. Running a D is really not a good suggestion of any kind unless you can find a gearbox like mentioned to help that motor. Just sayin.
    Shell Knob, MO
    My answer to your question remains the same. But I agree with the above posts of the gear box and other ways to make that motor more usable.
    Duane HTP
    Albuquerque,N.M.
    Quote Originally Posted by Spiritof76Cobra View Post
    it started out to be a 565. ended up using the short block for another project. I do have access to 2 underdrives an 17% and a 25% and may try it later.
    Albuquerque,N.M.
    Chris
    i havn't given any thoughts to imp cut yet. was just thinking about making a change to see what would happen. a imp change would be cheaper than a eng or underdrive. i added a 300 shot to it for this year if the boat doesn't sell. I've also have the data sys finished so i should have better info to tune with. whats your thought on removing the preloader?
    Removing the inducer will have no effect on the rpm you operate at. We have inducers in everything these days and we really can't get by without them in a race application, the dps was some times a crap shoot but the latest design is always a good thing from what we have seen.
    With a cut as small as your talking you will want the inducer.
    I don't have my impeller charts in front of me and won't be back in the shop till Tuesday but I'm thinking your going to have a hard time getting that engine to get into its sweet spot without a gear box. I'd have to look at my charts to be sure.
    B1Racing.net
