the electric fuel pump died in the southwind 18footer.
it was feeding a stock 460 BBF with a single holley vac secondary carb
i'm looking for suggestions.
i don't think it had a regulator.
I've run this Carter in Outboard applications, (I know, outboard = weedwhacker. but I'm a newbie) with good results. The Holly marine pumps seem to foul up easier if any foriegn matter gets in them. They just seem to be heavier duty. My .02
http://www.summitracing.com/parts/CRT-P4389/
I have got both a carter mech and a carter elect ....I put my mech back on and ran 1/2 fuel line to it. Might sell the electric rotary...has one season on it. Same as the one linked(6psi with 1/4 npt)Its feeding a 460 with a 750 vac sec.
Made In The Shade
Custom Window Tinting
I have a real nice Product Engineering 270 pump for sale. Great pumps.
Product Engineering 270 Fuel Pump
X's Two on the Aeromotive , had 2 of another popular brand fail last season , money well spent
Weldon A600A or for higher HP 1100A flow through fuel pump w/regulator.
Call Clay Smith Engineering. Get one of their mechanical pumps. It will feed 2 carbs & up to 1,000 hp, no problem. It can also be rebuilt when it wears out. Never had one wear out on me in 6 years, but if it does, it CAN be.
Wouldn't even consider using a cheaper electric pump on a boat, as they're no good unless gravity fed with WELL FILTERED FUEL, and if they have problems, you're just floating.
Curt
Ford Performance
R you running an inline fuse?
I've read alot of good things about the Aeromotive pumps. If you're thinking about getting one be sure to do your research. In your post you stated that you're not running a regulator. I checked on the 11203 pump that Chris recommended and the 2 most popular performance sites that sell this pump give different info. Jegs shows that pump is internally regulated @ 7 psi and "should" not require a seperate regulator on "most" carburetors. Summit shows that same pump to have a max pressure of 14 psi. Aeroforce also makes a marine version which is part #11212 and Summit shows it to have a max pressure of 7 psi and it is good for up to north of 500 hp. I don't know what the difference is between marine and non-marine pumps as far as Aeromotive goes, but I do know that with Holley their marine pumps are built using materials that are more resistant to contaminated fuel which can be a problem when you buy fuel at the ramps.
I'm not sure about fuel where you are, but here they put about 10% ethanol in ours. It's been hard on fuel pumps and carbs, at least it has been on mine. You may want one that is alcohol compatible.
