Place Diverted ride plate
Results 1 to 11 of 11
    Member milpitasjet's Avatar
    Default Place Diverted ride plate
    They have a ride plate that bolts to your droop. Any neg or pos info on these? Thanks in advace
    Member chevellesb406's Avatar
    Nov 2011
    Yorba Linda, CA
    curious about this myself as my new droop is a Place and can accept this bolt on deal.
    Heres the basic setup you folks are refering to , Milpitas note it requires the actual PD droop to bolt up the plate and Chevelle , it certainly couldn't hurt to add it to your setup Tom
    Thanks for the info tom, I have the pd droop. Just wanted to make sure its not a shitty set up. Thanks
    Feb 2012
    OC, CA
    Last I heard they weren't offering the ride plate any longer. Let us know if they are.
    Quote Originally Posted by Ol Blue View Post
    They slowed this product a bit a year or so but there available (and have been of a while) again Tom
    I added one of these to my boat last year. Before it would pourpus real bad unless you were FT. also my boat rode real wet. Put this on and it fixed everything. No more pourpus and rides much dryer. Seems to handle much better also on low end and top end..
    thanks for the info.
    Member morning wood's Avatar
    Jun 2010
    I bought the droop and ride plate through CP Performance and put it on last summer.
    It did a lot to clean up the wake and make for better skiing.
    Not really faster, but a big improvement. Plus it was on the boat with an hour of work.
    21' Ultra LX open bow (heavy) 454, Dominator pump with diverter.
    PS I called the guys at Place with a quick question and they were super helpful.
    Good luck
    Mark
    Thanks for the info mwood.
    Senior Member N2GLOCK's Avatar
    Oct 2010
    I called PD yesterday and they are still making the ride plate for their droop. Also, the droop is available alone and the ride plate can be purchased and added at a later date. One thing that I found interesting was that the the guy I spoke to said that the PD droop is longer and has more downward angle than my American Turbine droop. He said that their droop will lift my boat aot of the water more. I don't know if this is true or a sales pitch. I need to research some more.
