i have acquired an American turbine bowl...i think it is an A-309...i know it is off a jacuzzi energizer kit.
will this bowl bolt on and work on a berk JB OR JC ???
any machining needed ???
will my transom plate on berk work ??? (not setback)
i have heard good things about AT bowls and thinking about switching out or giving it to my cousin who is currently looking for a split bowl............
The Jacuzzi energizer kit bowls wil not work. They use the standard O.D. bowl but the jacuzzi uses 3/8 bolts , instead of the Berk 1/2" x 13. Also the bolt circle is different. jim
here is an American turbine bowl on a ledgend housing I just did. You can drill the bowl to fit if the inside Dia is 9 1/8 in the bowl[early energizer's]
