where to hit her with lube?
Page 1 of 2 12 LastLast
Results 1 to 14 of 20
    Douglas, MA
    Default where to hit her with lube?
    I know there is a zerk where the driveline goes in...any others I should be greasing?
    " where to hit her with lube?"
    In the sweet spot of course ................
    S CP
    Mar 2010
    Clarksville, TN
    Licker in tha Front and Poker in tha Rear
    WFLC
    Maple Ridge B.C. Canada
    don't forget oil in the bowl. alot of guy's (myself included) put nipples on the bowl and replace the oil with grease
    Senior Member hpltree's Avatar
    Sep 2011
    ventura , ca
    Default bowl grease
    i have heard the same , about adding grease to the bowl.. do you fill it with the same stuff you pump in the bearing... and do you just fill it up till it comes out the other side ??
    i don't know what u used. I use penz. red stuff. nipple on one side ,plug on the other , pump er till it comes out clean ,once at the begining of the season ,maybe again say aug.
    I do the same on my bowl....red n tacky. I use it in all areas; wheel bearings, thrust bearing, steering tube and bowl.
    Made In The Shade
    Custom Window Tinting
    X's 2 on the Lucas Red and Tacky its the shizzle ! oil in Berk bowls though whenever still possible .. Tom
    Sep 2011
    ventura , ca
    Default bowl grease
    super thanks guys red n tacky it is good info
    Jet boat service
    Sebastopol Cal.
    I agree with Tom here... I never could figure out why people put grease in a Berkeley bowl, unless it has been converted. Oil lubes better and curculates thru the bearings keeping them cooler( thats what the two little holes are for behind the bowl sea)l. Not only that but bowls designed for grease have an inside E clip to keep the seal from blowing out when you pump in the grease. I know I am going to get flak for my O2 but Berk and Legend bowls are designed for oil....use it if you can... Jim
    does the oil or grease lube a bearing or a brass bushing?
  13. #12
    The Right Coast/SE-PA
    Quote Originally Posted by rogerroost View Post
    No "bearing" in there just a bushing. And here's why I do NOT use grease > the bowl will never get hot enough to liquefy the grease...once that shaft starts spinning the grease won't be where it's needed, and that's (IF) it ever got between the bushing and shaft in the first place (doubtful) > oil flows between the shaft and bushing
    And no need for high $$$$ synthetic gear oils there, heck the cheapest gear oil or even thick straight 50wt oil will do.
  14. #13
    Douglas, MA
    How do you get it into the bowl?
  15. #14
    I put a zerk on one side and slowly filled till it came out the other hole.
    Made In The Shade
