Hello all!, I am new to the forum and this will be my 1st post. My name is Travis, I recently purchased a 74' sleekcraft 17' with a sbc350 that was taken out of a van, and a berkeley 12jc. When i purchased the boat, the guy gave me another impeller and told me it was for a BBC. My problem is that when on the water, my boat tops out at about 35mph at 4,000 rpm. I replaced the intake and carb with edelbrock performer parts, new distrib, new plugs, and am still having the same problem.
I have aquired a BBC 454 out of a winebago, that i have though about trying to put in the boat, but am missing the exhaust logs for a big block. Also I think id rather have the small block just bc of gas consumption, and i dont need a 1/4 mile boat. Im looking for a top speed around 60MPH, somthing that will pull a skier and a couple friends around the lake.
also, at 3/4 to 4/4 throttle the boat sorta chokes out and stops accelerating, does it need a high volume fuel pump with that edelbrock?
what do i need to do to make this boat work like it should? what impeller should i be using? how do i distinguish between the impellers? if and when i take my pump apart, what should i look at to see if it needs to be repaired? should my motor have an exposed flywheel? where can i find a bell housing that will work with the drive line? does my small block need a different cam for marine application? how about heads ( i have a set of 80's corvette 305 H.O. heads that im told will give me more compression, should i install these?)?
thank you everyone for your future responses. i will be checking back frequently!!!
p.s. Ive wasted about 5 trips this season to the lake with a boat that doesnt work... please someone shed some light on this bc i obviously dont know what im doing.
LinkBack URL
About LinkBacks
