Impeller size verification
Results 1 to 3 of 3
    Carlsbad, Long Beach, Big River California, United States
    Default Impeller size verification
    Big side is 9"
    Little side is 7.25"
    Angle is 125*-90*= 35*
    So is this an "A" ?
    1978 Southwind Tunnel Dragster
    LS powered
    1. The impeller is marked AB.
    2. Your "small diameter" measurement is being taken at the wrong point. You need to measure the smallest diameter of the exit vane. From the third pic, I estimate that to be about 1/4" less than the 7.25" you show in pic #2, giving a minor diameter of 7.0" which would fall right between an A(7.25") and a B(6.75"), hence AB.
    3. The angle shown is actually 180 - 125 = 55 degrees. An A would be 60 degrees.
    Thank you
    LS powered
