Water pressure BBF - Page 4
Page 4 of 4 FirstFirst 1234
Results 43 to 48 of 48
Water pressure BBF
  1. #43
    77 sleek. corbin5754's Avatar
    Aug 2011
    indy.
    Ya I have a gate valve I need to switch that out. I'll go to lowes and see if I vant find a relief valve of 15psi.
    Apr 2012
    jet mad i found a preset at 30psi
    Shop Watts 3/4 IN Boiler Pressure Relief Valve at Lowes.com
    its by watts company. whats the brand on yours and whats the adjustable range?
  4. #45
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Super Joe,
    I imported mine from Duane at HTP (High Tec Performance Inc).
    The relief valve is adjustable, 0-400 PSI, mine is set at 15 PSI - I had a pressure gauge custom made that reads from 0 - 30 PSI with a white face up to 15PSI. From 15PSI -30PSI it is colored red.
    The way my system is plumbed the valve is only there as a fail safe.
    I have preset mine with compressed air and did the fine tuning on the water.
    Gate valve is fully opened.
    Wikus
  5. #46
    Apr 2012
    very nice. i like the gauge idea as well. is it dash mounted by the way? can you share a price for the valve or should i contact him?
  6. #47
    The gauge I had locally made.
    The reason I chose this particular valve is the T-handle adjuster and it has a lock nut that prevents the valve from loosing its setting.
    Duane is a super nice guy and very helpful - look him up on his website - it will be money well spent.
    My gauge is mounted on the engine next to the dizzy.
    Wikus
  7. #48
    Orlando.FL
    Home Depot or Lowes have water pressurs guages with recall so you don't have to keep looking at the guage, $10
