question for impeller guys
Results 1 to 5 of 5
    Senior Member wajetboy's Avatar
    Auburn, WA
    Default question for impeller guys
    if you had an A impeller with a 36 degree machine angle instead of a 30 degree, how would this make the impeller perform differently?
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    B1 Racing cs19's Avatar
    It will certainly rev higher with that angle on it. Weve been playing with some of these angles lately too.
    B1Racing.net
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    Is it affecting flow
    Turn left
    Auburn, WA
    thanks chris, i thought it would bite harder. i will be testing it out this weekend. my impeller is getting cut to a 30 degree angle today from a 36.
    Auburn, WA
    here is a picture of what im talking about impeller is at 36 degrees and scribe line is at 30. it would remove a bit of meterial is why i thought is would allow the motor to rev more.
