Project Jimmy Johnson TX-19
Page 1 of 2 12 LastLast
Results 1 to 14 of 16
    Sep 2011
    Default Project Jimmy Johnson TX-19
    Drove 14 hrs straight to pick her up, after work and without sleep got home and already started making progress! It's got a bad drivers side stringer and various other things but nothing a willing and ready new owner can't handle! I have always loved these boats and cherished their design and functionality! I am retiring my v-bottom to a little stock lake boat and putting my monster motor in this one! Any suggestions on proper stringer replacement and do's and don'ts and what type of wood?
ID:	161619   Click image for larger version.
ID:	161620   Click image for larger version.
ID:	161621   Click image for larger version.
ID:	161622   Click image for larger version.
    Senior Member bc18's Avatar
    Quote Originally Posted by 525SC777 View Post
    Great boat lot of work ahead of you here. Pm TRG for wood choices and tips about replacing them he's done a handful
    Southwest corner AR
    Where are you located! I know of this boat and if you are replacing one stringer your best bet is to replace both and bulkhead too! Nice boat that just needed some fixing up! Good luck!
    It was a quick boat with the 475 motor too!
    WT
    WFL Crew!!!
    Sep 2011
    I'm in Cypress, Tx. The passenger stringer is solid as a rock though, and the bulk head? Why is it a must to replace both if only one is bad?
    Mar 2010
    Clarksville, TN
    That's Cordogs old boat. Should be a good runner after alittle TLC
    Good luck with it
    WFLC
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Nice project.I would move the MSD box out of the bilge.
    Sep 2011
    I know to move the msd box out of the bilge....come on!
    Sep 2011
    My new boat mentioned above Needs lots of TLC, that boat has been to say the least neglected the past few years and is in desperate need of a make over, about the only thing that is still nice is the paint! I restored my vhull "below" so my TX will get the same treatment!
ID:	161663   Click image for larger version.
    Mar 2010
    Clarksville, TN
    Really dig your vhull, super nice boat
    Your gonna love the winger, there aint nothin like em Did you get the engine with it or just the hull ??
    WFLC
    Sep 2011
    Bought it less motor, I have a solid roller 496 that made around 760hp that's in my vhull, thats going in it! I'm putting a stock 454 with a nice little bump stick back in my vhull with tunnel ram and 2 600 holleys. One of the nicest boats on the lake but doesn't like a bunch of hp it's been in my family since new in 1977.
    Mar 2010
    Clarksville, TN
    Should make that wiger fly !!!!!!!!!! I've read you other threads and it sounded like you was pushing the limits of the hull you had so you'll really enjoy this little project when you get er done .. Keep the pics coming and come on over and join us in the WFLC
    WFLC
  13. #12
    Southwest corner AR
    Dont take me wrong! But if the stringer is the same age as the other one it won't be long before it goes bad IMO! I was just thinking that it would be like taking a 454 BBC and putting new rings in one side and not the other! To replace the stringers all the way the bulkhead has to be removed in the process so a new one goes back in! This is your project and you do as you like I am just not a half way person and from the looks of your V hull you are not either! Good Luck with your project!
    WT
    WFL Crew!!!
  14. #13
    Sep 2011
    Your right I'm going to do both the bulk head is going to be a bitch!!!!
  15. #14
    Senior Member SEEIN RED's Avatar
    HOUSTON TEXAS
    We are doing the same thing to my Sons Tx 19 now also but once done i believe it will be a much nicer safer boat . We hope to finish this year but bringing one back is going to take awhile .
