electrical-wiring help
Results 1 to 8 of 8
    Apr 2010
    Default electrical-wiring help
    I've got no power to either lead going to the fuel pump
    where do I go from here.
    i've got a full charge on the battery
    and no juice to the pump,
    nor any power to the little harness at the back of the motor.
    the ignition wire at the ignition switch is hot when in the run position.
    the tester shows no power to the coil either (how is this supposed to be checked.
    I'm lost.
    HELP
    460 ford southwind
    the thing died on the trailer when winterizing the primary carb bowl was dry and the pump made no noise (like normal.)
    i've already bought a replacement pump
    but don't want to put it in if i get no power to it
    Member lenker's Avatar
    Costa Mesa
    if the power lead to the pump has no power, then trace it back to its power source to find the problem. if the power lead is does hove power and its still not working then its a ground issue. also check for blown fuses.
    Brett Lenk
    Missinglenkmotorsports.com
    Senior Member md-11mike's Avatar
    May 2012
    Thousand Oaks Ca
    Quote Originally Posted by southwind74 View Post
    I'm lost.
    HELP
    460 ford southwind
    A fuse somewhere maybe? Not sure how they wired their boats. What year boat is it. Is the wire coloring per the standard color codes? Older boats didnt use a standardized wire color.
    Apr 2010
    Quote Originally Posted by md-11mike View Post
    not sure what standard is
    its a 74
    I can't find one fuse on the boat
    Senior Member bc18's Avatar
    how about a tripped breaker?
    May 2012
    Thousand Oaks Ca
    its a 74
    Take a look here Marine Color Codes | Marinco . if it is a 74 this for sure wont apply. are there any fusable links in the system. Otherwise keep working backward until you can find power.
    Chico, Ca
    Ok, I don't want to sound like a jerk, but from the sound of your post, you are in over your head. What you need to do is post up your where you live and how much beer you are willing to sacrafice as payment for the help of someone that can diagnose an electrical fault. If that doesn't work you should find a local shop that knows what they are doing.
    Before all this though, if you have a bright red button mounted on the wiring terminal block mounted on the back of your engine. Push it, if it clicks in, then check power again. If that doesn't work continue on with the first suggestion I gave.
    Andrew
    Andrew
    They arnt always red some are white. Same as I said its like a 65 amp breaker. Push it and see if it clicks
