ski tow with aluminum heads ?
Results 1 to 5 of 5
    Senior Member bigblock68's Avatar
    Default ski tow with aluminum heads ?
    ski tow with aluminum heads i have the 2 top bolts in the heads and 2 bottom ones in the block will the heads take the pull
    Senior Member GRoper's Avatar
    Good question. I've wondered this also. Id think you would be ok.
    May 2011
    Cen Cal
    Quote Originally Posted by bigblock68 View Post
    No, so you might as well toss out the ski tow.... dont worry i'll dispose of it for ya
    Jk should be fine
    Senior Member riverslide's Avatar
    Jun 2011
    Riverside
    Works just fine... I have used this setup for many years.
    Edit miss read the Q orig. I have a ski pylon...and alum heads...so far so good. I havent pulled a skier....but I have pulled my tube with 3 people before.
