Harman marine 460 Logs ?
Results 1 to 5 of 5
    Default Harman marine 460 Logs ?
    I just got a det of these and was wondering if ther is a correct in and our for the water? Both of the fittings are on the same end and on the same plane.
    I use the inside front from pump and the outside to water block off....I ran -10 5/8 to a T under balancer/front motor mount(made a bracket and drilled/tapped). Then made the inlet lines as close as possible in length to inner log fitting. All in -10 push lock 5/8 hose.
    Made In The Shade
    Custom Window Tinting
    Default Thanks
    Just to be clear, you feed from the logs on the inside fitting and exit on the outside fitting? Do you happen to know if it makes any difference? Are they designed to flow that way?
    Correct but its easier as you will see to have it run the way I have for clearance as your stringers are right under the outside holes. Either way is fine as water in water out...They are the best style for ford as they are the only style for ford that allows the water to flow up near the port and you can use a good set of felpros and never have a leak at port.
    Made In The Shade
    Default Thanks Krusn
    I don't have any clearance issues, just was wondering if ther was an in and out on these, some are obvious.
    thanks again!
