Cavitation plates
Results 1 to 9 of 9
Cavitation plates
    Jun 2012
    Default Cavitation plates
    I have a friend who has quite a bit of marine knowledge. He suggested I put plates on my boat as it will make it faster and smoother in rough water. It is a Rogers Super Cyclone 18ft. In all the pictures I have seen of these boats I have never seen any plates. Any thoughts or comments on this?
    Thanks,
    Rob
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    What's your current setup? Do you have a ride plate/shoe? What kind of HP do you have. We are currently running 93 MPH with a ride plate and it handles great.
    Quote Originally Posted by 464Saloon View Post
    Thanks,
    Rob
    Just curious if your expirienceing an issue of some sort or trying to resolve a problem ? I have a boat for example that were in process of developing a plate system for in an attempt to resolve a specific handling problem Tom
    Jun 2012
    Quote Originally Posted by 76 Bonneville View Post
    Not sure what you mean by current set up. Its a 454 which I just rebuilt and fired two days ago. Its the origional engine that came in the boat. It has a Berkely jet with a B impellar that was rebuilt by Harmon Marine a couple of years ago. It doesn't have but a few hours on it.
    Jun 2012
    Nothing really that isn't characteristic ( from what I understand and have experienced) of the old shallow vee boats. Great in smooth water but almost useless in anything else. My friend explained to me with a ride plate it will keep the nose slicing through the water instead of the back pushing through and causing the dreaded bounce in rough water. I was caught once on Lake Mead in pretty rough water. I left the camp site for the harbor 30 minutes before the others with their boats. All newer with deeper hulls. I was lucky to maintain 15 mph and that the boat or me didn't break in half. They all passed me up and were enjoying a cold one by the time I got in.
    Jun 2012
    Not sure on the horsepower. I would think it is a solid 500+. It's now .030 over with 10 to 1, balanced, rectangular port heads with some port massaging. Comp 278 marine (jet) cam with roller rockers, Weiand Team G manifold with spacer and 850 Holley DP, Rewarder headers, and recurved HEI ignition.
    Senior Member wolfie's Avatar
    On the lake in Utah, United States
    It's the hull that causes that. If you have a shallow V, you're going to have a rough ride in bad water. Those type of hulls will never ride well in rough water.
    That being said, if you're running a trim device, trimming the bow down will accomplish what you're trying to do with cav plates for a lot cheaper.
    The best thing is to pick your day and time.
    Jun 2012
    Quote Originally Posted by wolfie View Post
    Last I checked a trim unit for my boat was around 700 for manual control and 900 for electric control. Putting plates on the back would be more than that?
    It won't do what you think it will. A Place Diverter will allow you to adjust the attitude of your boat. They were designed for jet boats. Cav plates have been used on some boats but certain types of boats. Cav plates on a jet can be used in conjunction with a trim device. Call tom at Jet Boat Performance. He'll set you up with what you really need and explain the reasons clearer than I can in a post. My old feeble mind won't let my fingers type what's in my mind today! I guess it was one too many beers yesterday.
