more. did you not dyno the thing?
the first time i put my sw in the water 11 years ago with a PUMP GAS 538, it ran 101/10.13. it wasn't a gps reading. i only had 10 gallons in the side tanks at the time. but i know what the observed numbers were, i know what impeller was in it and i know the rpm it turned. the last year they ran the 1/2 second brackets at ming, it ran 111/9.48. turning the same cut impeller virtually the same rpm.
looking at my most recent dyno sheet, compared to the rpm i'm turning the impeller, the chart isn't remotely close to accurate.
you're doing well with it, and that's great to see. but your engine would have to be pretty fracked up to gain another 50hp just in tuning. the gains are going to happen working the setup. i'm not suggesting you'll ever pick up 10 mph or over a half second of et. but the setup is where the improvements will come from. keep workin it - it's never perfect...![]()
LinkBack URL
About LinkBacks
is this is a river boat and takes us up and down the river almost every other weekend....many times ten to fifteen mile trips to find beachs or visit the dam.
