Funjet mini jet rebuild
Page 1 of 4 1234 LastLast
Results 1 to 14 of 45
    small member spam's Avatar
    On the water
    Default Funjet mini jet rebuild
    I picked this boat up last summer and just now got into it. I was able to get the motor running easy when i first got it but never took it out. I knew i would have to do some work to it as it looks as if the nozzle had been damaged at one time the modified to work. I was hoping to install a diverter on it since some mods are needed.
    I took the bowl off tonight and saw that is was pretty bad inside.
    So first question would be can someone help id the pump and do you know if parts to rebuild are out there.
    attached are some pics and i will follow up with some more soon. its a pretty cool boat.
    Funjet is the make. gotta take a tape to it for exact length as it has slipped my mindClick image for larger version.
    It has a 60 hp 2 stoke motor hooked to the jet.
    On the water
ID:	165399Click image for larger version.
ID:	165400Click image for larger version.
ID:	165401Click image for larger version.
ID:	165402Click image for larger version.
    Senior Member LIL WAKE's Avatar
    Sep 2011
    Minneapolis, MN
    Awesome! You don't see too many mini jet boats out there. It's hard to fit a decent size engine/pump in such a small boat. I am building a custom mini jet boat out of an Addictor. I love your boat and can't wait to see you bring it back to life. It looks to be in pretty good condition for the age! Hope someone chimes in to help you ID the pump. Good luck and please keep us posted!
    On the water
    Quote Originally Posted by LIL WAKE View Post
    there is a website for the name tag i posted. they have a mini jet on there but a different brand then funjet. I am in contact with them to see if they have parts for pump.
    bowl is torn up and will need replaced the impeller shaft has alot of wobble in it so it will need complete overhaul if not a new pump if i can not find parts.
    Your project is awesome i have been watching your work. Very impressed on how it is turning our for you.
    Mini jets are cool for sure. Looks like they are gaining popularity.
    i had my eye on mine for a year before i picked it up. it was just sitting out in the middle of no where on a 2 lane highway with a sign.
    On the water
    Boat measures just over 10'. these are better pictures of motor and pump
ID:	165527Click image for larger version.
ID:	165528Click image for larger version.
ID:	165529Click image for larger version.
ID:	165530Click image for larger version.
    Senior Member bartel's Avatar
    Mar 2010
    how is this little build coming along. It would be cool to have a meet up with the mini boats we are all working on. mine is moving slow due to issues getting parts but i hope to have her up and running by the end of the season
    2006 22ft Placecraft 496 Mag
    On the water
    From what i can tell the pump is a Morita. Seems parts are hard to come by from a thread i came across. There is a small glimmer of hope as i found 2 websites that may be able to help and also may have found a complete pump and motor set up for it of the same make.
    On the water
    Motor compartment usable space is 23" wide x 33" front to back.
    If any one has an idea of a ski motor/jet combo that may fit feel free to give suggestions
    thanks
    On the water
    Got an email back form someone who says they have all the parts i will need in new old stock and i also found 2 complete pumps to look at. I am hoping the new parts do not cost an arm and a leg
ID:	165693Click image for larger version.
ID:	165694Click image for larger version.
ID:	165695Click image for larger version.
    On the water
    So with some research. i have found that this is the same motor jet combo that came in alot of the wetbikes in the late 80s and 90s. After the Funjet they came out with a new model which is know as the Jetstar which is 12 to 13 feet and wider and seats 3 people.
    I have found a new pump complete as well as a used one plus it seems the parts are out there for these still you just have to do some work. Of course my budget will be over what i wanted but when is it not. So the good news is i can continue with out much delay other then funding
    On the water
    so i got this from ups today. I found it on ebayfor just under $250. It is off a wet bike. It looks to me that most parts arean exact match with the exception of the suction housing which on the jet boat has. houses so water can enter and exit motor .
    The impeller shaft is in great shape compared to myoriginal one as well as the impeller. the bowl is in a lot better shape as wellas its bearings are still good. One vein has a small chuck out of it.
    Now i was going to have to modify my old bowl towork and i will have to do the same with this one as well since it came off awet bike. i had a thought of welding a berk nozzle housing to it so i can mounta diverter if wanted but i am unsure if the 2 parts can be welded together. Ihad also thought of making a mount that i can bolt the nozzle adapter to buthave not thought of any clean ways to do it at this time
ID:	167367Click image for larger version.
ID:	167368Click image for larger version.
ID:	167369Click image for larger version.
ID:	167370Click image for larger version.
ID:	167372Click image for larger version.
  13. #12
    Senior Member puppyjp's Avatar
    May 2010
    Rives, TN
    My introduction to jet boats was with a fun jet.
  14. #13
    Senior Member slow67's Avatar
    DFW
    I wouldn't do the berk nozzle, the diameter of the nozzle is smaller than a berk nozzle (unless you open op the old nozzle and machine a nozzle in the place diverter that matches the stock nozzle).
  15. #14
    On the water
    Quote Originally Posted by puppyjp View Post
    Do you still have yours? what was your avg. speed?
    Quote Originally Posted by slow67 View Post
    The funjet nozzle is alot bigger and i do not think will perform as well. i will post pics of the 2 to compare. The bowl will need to be modified as i did plan on opening the bowl to match the berk nozzle just placed there to get the idea i had.
    Now i have welded before but would not call my self a pro by any means so if the 2 parts can be welded together any suggestions on a place i can take it would be appriciated. i live in lake elsinore.
    thanks
