Diesel oil and zink - Page 2
Page 2 of 2 FirstFirst 12
Results 15 to 19 of 19
Diesel oil and zink
  1. #15
    So Cal
    I kind of have information on this ... just a little lol
    Rotella T3 and/or Tripple Protection has a 15w-40 with ZDDP count about 1200ppm
    Regularly available at all auto parts stores and WalMart too.
    Not only can you use in your tow vehicle ... but in your boats engine as well.
    As far as additives ... Torco's MPZ Magnetic Friction Reducer is the way to go if you feel the need to add one. If you're like me & are anal about oil changes and wear ... this is a no brainer ... add it.
    That's my combo, Rotella T3 & MPZ MFR
    The Right Coast/SE-PA
    Quote Originally Posted by BLUE BOMBER View Post
    ok big hammer what do you think of my mixture of running the blue premimum and the ZDDPlus additive. i personally think i would have a winning combination with that
    Honestly I don't know???
    Guess my response would be > why not just run a good quality performance oil that already has what you need in it?
    Just wondering but, what make us believe "diesel rated" oil has an edge over a quality off-road/racing oil?
    Diesel oil is heavily designed to suspend the 'soot' produced by the it's 'compression' engine.
    I kinda like and use Valvoline VR1 synthetic Racing oil. 20/50
    Prior to that I was all about Brad Penn Racing straight 50...but I do believe the 20/50 has a better pump-ability to it when start up occurs...and...it makes it's way back to the oil pick-up faster. (just my way of thinking) Plus it's Synthetic > I notice it takes more load time to build heat in the oil and the oil holds pressure better ans does run cooler vs dino.
  4. #17
    This is a PDF email i just recieved from the people over at lucas. The facts dont lie about there stuff.
    Bitmap
    Lucas Motor Oil
    Typical Zinc Values
    Quart Description Zinc PPM Quart Description Zinc PPM
    Part #'s Motor Oil Part #'s Motorcycle Oil
    10179 Syn SAE 0W-30 1,265 10700 SAE 20W-50 1,058
    10211 Syn SAE 0W-40 1,265 10702 Syn SAE 20W-50 1,058
    10082 Syn SAE 5W-20 API 861 10704 Syn SAE 5W-20 1,058
    10049 Syn SAE 5W-30 API 861 10706 Syn SAE 5W-30 1,058
    10189 Syn SAE 5w-40 API 861 10708 Syn SAE 10W-30 1,058
    10050 Syn SAE 10W-30 API 861 10710 Semi-Syn 10W-40 1,058
    10176 Semi-Syn SAE 10W-40 1,265 10712 50W 1,058
    10054 Syn SAE 20W-50 1,265 10714 70W 1,058
    10516 SAE 5W-20 API 861 10716 Syn SAE 10W-50 1,058
    10474 SAE 5W-30 API 861 10718 Syn SAE 0W-40 1,058
    10276 SAE 10W-30 API 861 10720 Semi Syn SAE 10W-40 ATV 1,058
    10275 SAE 10W-40 API 861 10765 Syn 50W 1,542
    10252 SAE 20W-50 API 861 10767 SAE 10W-40 1,058
    10162 SAE 40WT API 861 10777 SAE Syn 10W-40 Moly 1,058
    10053 30 Plus 1,265 Quart #'s Break-In Oil
    10044 50 Plus 3,921 10626 SAE 20 3,634
    10261 70 Plus 5,458 10630 SAE 30 3,634
    Quart #'s Racing Only Oil 10635 SAE 20W-50 3,634
    10281 Syn SAE 0W-5 4,836 Quart #'s Heavy Duty Diesel
    10286 Syn SAE 0W-10 3,289 10075 SAE 15w-40 CI 4 Magnum 1,524
    10291 Syn SAE 0W-20 3,218 10298 Syn 15w-40 CJ 4 API 1,281
    10605 Syn SAE 0W-30 2,616 10296 SAE 15w-40 CJ 4 API 1,281
    10610 Syn SAE 10W-30 3,097 10435 Syn 5w-40 CJ 4 API 1,362
    10615 Syn SAE 20W-50 3,132 10571 SAE 10w30 CJ 4 API 5 gal 1,281
    10306 Semi-Syn SAE 20W-50 3,115
    10620 SAE 20W-50 3,132 Pint # Engine Break In Oil Additive
    10380 Jr. Drag SAE 5W-20 15 oz 6,795 10063 TB Zinc Plus 35,000+
    3x1/5 qt. Hot Rod & Classic Car Oil Mix Ratio Zinc PPM
    10679 SAE 10W-30 2,100 10063 4.5 qt Oil + 16oz Zinc Plus 5,000+
    10683 SAE 10W-40 2,100 10063 4.75 qt Oil + 8oz Zinc Plus 2,500+
    10684 SAE 20W-50 2,100 10063 4.9 qt Oil + 4oz Zinc Plus 1,250+
    Quart #'s Extreme Duty Marine Oil
    10653 SAE 20W-50 3,132 Lucas Oil Products
    10654 Semi-Syn SAE 20W-50 3,115 302 North Sheridan Street
    10661 Syn SAE 10W-30 Outboard 820 CORONA, CA. 92880-2067
    10662 Syn SAE 10W-40 Outboard 820 PHONE: 1-800-342-2512
    10677 SAE 25W-40 Inb Strn Drv 820 FAX: 1-951-270-1902
    E-MAIL: www.LucasOil.com
    Great chart for "Lucas motor oil" not knocking it, but questioning why bother with the "stabilizer"?
    Ask Lucas for a breakdown chart/additive package of what's in their "oil stabilizer" > and that's what put them on the map.
    I gotta think the 'stabilizer' just gives it's user a warm-fuzzy feeling about using it, nothing more...and that's good marketing
    This seems like the ticket...Extreme Duty Marine Oil
    SAE 20W-50 3,132
  5. #18
    San Clemente
    I like the valvoline because of the price for starters, i have been runnin it for a while thats why i havent decided to switch to anything else. I dont like racing oil for only one reason not alot of detergint. other then that it kicks ass. due to the fact i got a 25 year old engine that sits half a year with oil just sitting in it i think the detergint is a good idea to keep things clean.
    I started out on this little quest because alot of people believe in there theorys and i think thats great and not knocking them. even i got my little lame ass theorys on why i run what i do too. i wanted the facts for my self, however all i could find is data that was old from 07 and 08, and a little form 10. I know that this stuff due to our gracious government is changing all the time.
    So i called and got the facts for myself, in 2008 valvoline premimum blue had 1400 ppm, getting off the phone with ron at valvoline corporate it now has between 900 and 1000. these are the facts and thats what i wanted to know and share them with the community, i think they are important.
    I would have to agree with you about the oil stabilizer, i have used it many times, i dont think it is anything amaising, i agree it is a feel good can. I got to tell you i find it funny that it isnt listed on the chart they sent me. wouldnt you think an oil additive would have a high amount of ZDDP and they would want to show that.
    The rest of the summer i am gonna run what i got in there and add some ZDDP additive, either the ZDDPlus or maybe the lucas additive. i only wanns get to 2000 ppm ZDDP, because to much can be harmfull.
    As for next year maybe run what i did this summer again, maybe do the lucas marine oil way bad ass. or maybe crack open the 3 cases of VR1 i have at my shop because the class 1 that use to have we sold and we arent gonna use it for the other cars because motor builders are weird amount what you run. imagine that haha.
  6. #19
    Senior Member SBS933's Avatar
    Jun 2012
    Cool I Agree
    I Agree with Jet Pilot, I follow Dale in Hesperia's advice he has a deep knowlege on boats. I find it hard to get there for oil so I run Royal Purple 40 sae, with their filter and i run a sweet 70 psi oil pressure ,and I dump out a couple of quarts every time I go out and replace it just to keep it freshened up. it's a little expensive but if you don't want to take care of your boat then sell it.
