Edelbrock or Holley - Page 2
Page 2 of 2 FirstFirst 12
Results 15 to 23 of 23
Edelbrock or Holley
  1. #15
    sacramento
    what exactly is the problem with the edelbrocks? hard to tune ,bad transition of afr thru the rpms ? less flow per cfm than holley? inquiring minds would like to know.
    DEG
    DEG is online now
    Senior Member DEG's Avatar
    Mar 2012
    It's just what your going to do with it?
    Jet boat= Holley
    Daily driver= edelbrock
    I've never really had a problem with either one. They both have been around forever for a reason! I feel the Holley is a little bit quicker and the edelbrock is really dependable... Just my .08€
  4. #17
    Oct 2011
    Holley
  5. #18
    Senior Member stc315's Avatar
    Yuma, AZ
    I used to bracket race a 70 Nova with a 454 LS6 crate motor. I ran a 625 Carter (similar to Edelbrock) to the track and an 850 Holley DP for the racing. I'd bolt the Carter back on for the drive home. Averaged about 15mpg with Carter and mid 12's with the Holley.
  6. #19
    Newbury Park, Ca/Bullhead City Az
    Default Carbs?
    All three can be great carbs.... Personally, I'd go with the Holley just because of parts availability just about anywhere, simplicity, and "bang for the buck"......... That said, I prefer injection......But maybe not on a recreational boat....(or any black flatbottoms!!!)
    Ray
    LOUD BOATS SAVE LIVES
    3 OPEN flatbottom APBA seasons left.....Let's RACE
    HONK if you voted for obama........
    It's that button in the middle of the steering wheel........
  7. #20
    DEG
    DEG is online now
    Mar 2012
    Why doesn't anyone run stacks on a jet.. I just love the looks and sound can not be beat.. Name:  ImageUploadedByTapatalk1340859725.541516.jpg
  8. #21
    Morgan Hill
    Quote Originally Posted by DEG View Post
    GT
  9. #22
    Senior Member hpltree's Avatar
    Sep 2011
    ventura , ca
    Default holley
    holley all the way.. i have not had any time on the other carbs but i do know holleys and thats all i would run.. super easy to run and tune.. 750 dp on my 73 240 z with a small block conversion...plus a 9015 750 vac sec on my 454 boat. i should swap the two ,, maybe soon lol
ID:	166631   Click image for larger version.
Name:	Copy of Picture 065.jpg
ID:	166632   Click image for larger version.
  10. #23
    Strap on the JATO konajet74's Avatar
    Antioch,Ca
    9022 800dp Holley, stock jetted.......Perfect for your combo.
    My engine's close to your's & I verified it w/ a wide band.........
