Edelbrock or Holley
Page 1 of 2 12 LastLast
Results 1 to 14 of 23
Edelbrock or Holley
    May 2012
    Default Edelbrock or Holley
    Which is better? I will be running an 800 CFM on my 454 build which brand would you recommend?
    Castro Valley, Ca.
    holley
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2002 Corvette M-6 Coupe
    79 Cole TR-2 Sunset Racecraft 565
    Remember in November
    Well done USN Seal Team 6
    Senior Member vdrivegrimes's Avatar
    Oct 2011
    Quick fuel
    SWTD Member M/E 177 jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    x2 on the Holley!
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
    Mar 2010
    Clarksville, TN
    QUICK FUEL
    WFLC
    Kingman/Golden Vly, Az
    dont under estimate the Edelbrock 800cfm AVS carb ...just my .02 cents
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    =PILE!
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
    May 2012
    whats the upside to quick fuel? and wat series?
    Quote Originally Posted by RiverRat1989 View Post
    Very High Quality parts , good folks and What series is dependant on your build and application Tom
    May 2012
    Heres a breakdown of what will be done to it. Stock crank and rods, SRP small dome pistons at 4.280 bore, Stock large oval heads solid flat tappet cam and lifters and roller rockers. Stock deck height. about 10:1 compression ratio.
    Mar 2010
    Clarksville, TN
    The QF Q series are great for what we do .. Give QF a call and talk with Zach Baker, he'll get you what you need .. I'm a total dumb azz and even I can work on them, very user friendly
    WFLC
  13. #12
    Jul 2009
    Hesperia California
    I run an edlebrock on mine and I never have any problems, but mine if fairly stock. just my 2cents
  14. #13
    Iuka, Mississippi 38852
    X 2 on talking to Zach at Quick Fuel. You won`t be sorry you did.
  15. #14
    Menifee
    I love Edelbrocks. I had s 70 Chevelle with a Muncie 4 speed, BBC with an 850 Holley. When the emergency cable snapped on me nothing worked better to keep the car from rolling out of my driveway than stuffing that pile of shit Edelbrick carb under the front tire.
    Grest carbs when used as tire chalks.
    Keith...
