Hey guys im rebuilding a 91-up 454. and I need ideas on what I should do intake wise. Heres a breakdown of what will be done to it. Stock crank and rods, SRP small dome pistons at 4.280 bore, Stock large oval heads solid flat tappet cam and lifters and roller rockers. Stock deck height. Which route should I go?? Tunnel ram or just go with a standard airgap manifold with a single carb???
LinkBack URL
About LinkBacks
...you could use the Edelbrock 750cfm carb or a Holley 750cfm DP mech sec carb...both would work well...just my .02 cents
