Engine placement in a TX19 - Page 3
Page 3 of 7 FirstFirst 123456 ... LastLast
Results 29 to 42 of 85
  1. #29
    Senior Member Boost's Avatar
    Pomona ca
    Quote Originally Posted by lupo1904:1664206
    Boost, hows that thing shut down?
    Chris shuts down great, I'm more then happy with the whole setup on my boat, just wish it was a bit heavier, took a little test and tune time to get it dailed but that was the fun part.
    Q.C./Big River
    How are the real fast guys doin it with the smaller impellers. Theres got to be more to it when these jets are running down in the 7s. Not doubting what your sayin but just tryin to learn a few things like the rest. I know a AA is gonna hole shot like a Sumbitch but how are these guys makein these B/C do it?????
    Boost, boat looks killer!!!!
    There are no gullwings running in the 7's! Not 18' or 19'. Tunnels yes and that is because it is a totally different boat and I would bet dollars to donuts that they are runnng a launch control to get those small impellers to get them outta the water the way they do.
  4. #31
    Q.C./Big River
    Here is a pic of mine running at firebird. It runs better at the river but the set is good IMO and it took almost three years of trial and error, test this test that to get it to here.
  5. #32
    Pomona ca
    Good hanging with you Dennis a couple weeks back, your boat came along way,great job on the build.
  6. #33
    Q.C./Big River
    Quote Originally Posted by Boost View Post
    Same here bro. Didnt see you on sunday. Did you pack it up and head home? Thanks, it has been a long road of hard work and lots of $$$ but I am really happy with it now.
  7. #34
    Mar 2010
    Clarksville, TN
    True !!!!! Wasn't really referring to GW just jets in general. how does the launch control work???
    Guess I just jacked this thread all up, sorry to the OP
    My boat is pretty heavy and my engine sets 21" from the transom. It carries the nose pretty good and runs pretty dry. I'd like to see alittle more lift in the whole boat and get it ridein on the keel kinda like boosts boat but don't know if it will due to the weight. Thanks for the info Need4Speed
    WFLC
  8. #35
    Q.C./Big River
    My boat is heavy too. I am 190lbs and can walk on the deck all the way around the boat. It weighs about 600 bare. I run pretty dry and on the keel but it took a lot of work to get it there. My motor is 21" from the transom too but my pump is all the way out the back so that a pop off would clear the transom without hacking into the transom for it. so with the jetaway and drive line, and the pump all the way out the back, I am at 21". So it is definately doable.
  9. #36
    Mar 2010
    Clarksville, TN
    What kinda HP you runnin???
    My pump is stock location, half way in half way out. I done a few things over the winter and finally hit 100mph but I don't have a pick of it running so I'm not sure what it's doin. Our boats are pretty close to the same weight, I'm 680 without engine and interior
    WFLC
  10. #37
    Q.C./Big River
    900 hp
  11. #38
    Mar 2010
    Clarksville, TN
    I'm around 850, pretty close
    WFLC
  12. #39
    I run a BC imp, inducer, w/NO launch control and I flat foot it from a dead stop.
    Motor @ 23"
    2 1/2 degree backcut shoe
    Hyd diverter on timer
    6' blocker
    Full interior 650lbs hull & leaves hard like an 18'
    we run similar stuff in the #905 but with a launch control.
    back to lurking
  13. #40
    Mar 2010
    Clarksville, TN
    How does a launch control work in a jet???
    WFLC
  14. #41
    Atlanta, Texas, United States
    Basically one is controlling the acceleration rate of the engine on takeoff so that the engine is not out accelerating the pump. If one has enough power to accelrate the pump past the point of keeping the impeller loaded, and runs through the impeller, this "burnout" slows acceleration.
    There are various methods of controling from a simple switch or timer controlling a rev limiter or timing retard, to more elaborate slew rate controllers, etc.
  15. #42
    Mar 2010
    Clarksville, TN
    Thanks Gear
    WFLC
