Changing engine on 21 Daytona.....Engine Hoist Idea...please share them - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 15 to 28 of 42
  1. #15
    Senior Member Sleek Freak's Avatar
    Hooper Utah
    find a friend, neighbor or other place and just do it there.
    Oct 2011
    Where in Washington? I'm in Portland and you can always use my forklift. Tow it down, yank it out. Put motor in your tow vehicle for trip home. When wanting to put back in, your welcome to use
  4. #17
    Quote Originally Posted by Sleek Freak View Post
    Last week I backed a lifted truck into a friends shop, and used a shop lift to lift the engine up, and pulled the truck out. Lowered the engine on the stand and was done.
  5. #18
    An A-Frame is the only way to do it well, easily makes it a 1 person job. This one was bought at a garage sale for $10, and it has casters on the feet to move, and an I-Beam to move the weight left to right. You could easily make one out of 4x4's, 6x4's in your garage, and just attach it to already in place studs, just got to beef it up. Also you can get the hoists from Harbor Freight for cheap.
  6. #19
    Senior Member rebel30's Avatar
    Oct 2011
    Twin falls
    Default Cherry picker
    You could probly go to your local steel yard and get some box tubing that would fit inside the legs and boom . Measure what u have now then add 2 feet that should be enuff . I would do the legs 2 other wise it will tip over. Then just bolt ur wheels to the new pieces and drill the holes n the boom . Shouldn't set u back more than 50 bucks .
  7. #20
    Newbury Park, Ca/Bullhead City Az
    Default Cherry picker..
    When I had to install an engine in an ocean type cruiser w/outdrive, I put a standard cherry picker in the back of a pick up for additional height. I strapped the back of the picker around the bed to the mid point of the truck frame to keep it from tipping, and extended the beam to the last hole.... Worked great because the ram will go quite a ways down and allow the "up" travel you'll need to clear the boat once it's hung...You may have to remove the tailgate, and watch the truck bumper hitting the pump....Or come in from the side...
    Just another idea you might toss around and come up with something that will work for you....
    Ray
    PS I was installing a small V6, so be careful if it's a BBC....
    LOUD BOATS SAVE LIVES
    3 OPEN flatbottom APBA seasons left.....Let's RACE
    HONK if you voted for obama........
    It's that button in the middle of the steering wheel........
  8. #21
    Dallas, TX
    You need one of these.
  9. #22
    Costa Mesa, CA
    Do you know anyone with a forklift?
    I have got mine out solo with a standard hoist and even into the bed of my lifted truck. It will work, just be careful and patient.
  10. #23
    May 2012
    I like!
    1990 ultra 21' open bow. zz502,american turbine,crower cam, headers,plus more. A start to a jetboat(family) experience
  11. #24
    Apr 2011
    bethlehem pa
    Default cheap ass way...
  12. #25
    MD
    have motor ready then call a tow truck and have them lift it out.
  13. #26
    Hudson, Wisconsin
    Here's the easiest way. Recess a 3000# winch into the ceiling joist for max clearance! Jocko
Name:	Cougar FINISHED! 008.jpg
  14. #27
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    Your pretty crafty. Just build a gantry crane. Get the iron and then get a trolley at harbor freight for cheap.
    Or just use it as a good excuse to get a small cheap forklift!
  15. #28
    Salem,Or
    I like it !
    With Spray there is a way!!!
