split bowls
Results 1 to 6 of 6
split bowls
    Apr 2012
    Default split bowls
    in stock berk (not aftermarket) are the split bowls A B and G and the single bowl is a C? reading the C bowl will flow a bit better than the A and B but no one mentions a G as flow is rated.
    is there any ID marks that would help with what bowl is being sold on CL? seems everyone on CL thinks because its a split, its a G. or maybe there is a ton of G bowls for sale and no one has an A or B for sale.
    help me to understand the differences please
    The G bowl will have the oil fills at the same distance apart like C. The earlier bowl was real close.
    B bowl
    G bowl
    This is my C bowl thats been modified to be a split...
    Made In The Shade
    Custom Window Tinting
    Apr 2012
    krusn 56 thanks for the pics. thats very easy to see the difference.
    it may be the pics but does the B bowl not have a a straight section before the exit or is the G the same and the angle the pics at make it looks different?
    also a mod C bowl to be a split sounds intriguing. does this flow better than the standard split bowl? whats involved in doing this?
    They both straighten up...C bowl is rumored to flow better than G. I bought this off a local here in San Diego and was already modified. I still have my old C but wanted to try a snoot so had to switch bowls and got lucky that I found a split C.
    Heres a couple c bowl conversion links..
    JBP "C" split bowls
    C bowl to split bowl conversion
    Made In The Shade
    Apr 2012
    thats what i want to try. maybe i should spend some time in the spam area.
    your set up looks very clean. i like it a lot
    Quote Originally Posted by $uperJoe View Post
    Thanx...
    Made In The Shade
