Fuel system question? - Page 2
Page 2 of 2 FirstFirst 12
Results 15 to 17 of 17
  1. #15
    Are your tanks vented? Also, your pickups might have screens on them that might be plugged up.
    Feb 2012
    OC, CA
    Quote Originally Posted by MBMoseBilt View Post
    It's not a gravity feed it a siphon effect. Always try to place the pump below the tank pickup.
    True on the siphon effect, but you need gravity to prime it.
  4. #17
    Redding, CA
    Did it work before putting the Holley on?
    Or is this problem the reason you put a new pump on?
    My Holley blue is 5 years old, is mounted low on a stringer, pulls from both tanks, and will fill the lines and build 6 PSI in a matter of seconds.
    I also feel that more is made out of mounting them low than is really true, but it is certainly not something to be ignored. A dry fuel pump is a hot fuel pump, and that means certain failure.
    That is my main thought in mounting them low.
    It is possible that you have leaks in the pick up's near the top of the tanks, but seems unlikely iif it does it even with tanks isolated?
    It may not be the complete cure, but lowering it seems to me to be the first step.
    Tommy
    Quote Originally Posted by ram78d10 View Post
    I've talked with numerous teachers
    all the teachers I have talked to agree
    That's their problem, they can't print money.
    Quote Originally Posted by cvxjet View Post
    I rarely meet people that are smarter than me-
