Originally Posted by
Shaun
I've never understood all this talk about needing to mount a pump low so that gravity will feed it. My pump is mounted below my tanks but i run a filter/water separator up on the transom above the jetpump, above the fuel tanks. So my pump has to pump the fuel up the tank straw, across the transom, fill the fuel water/filter separator and then down to the pump. I've run Mallorys pumps like this for 15+ years, and now this year i just changed to an Aeromotive pump and I have never had a problem. Even if I change my filter or drain the system the pump never has had a problem pulling fuel.
I think your problem is else where personally, mounting your pump/lines/filter/whatever lower may band-aid the problem but something just doesn't seam right. That's just my opinion, i'm no expert.
