a guy do you know the clearange between the shaft and the bowl bearings ? on Berkeley 12JE
thanks.
thanks.
bowl bearings? i thought it was just a brass sleeve and a oil seal. i do not know the clearances, sorry
i stand corrected. thanks tom. is it a roller bearing or a ball bearing or what type is it??
ok thanks,
it's because i just metallized my shaft because it was used where it have the seal....
how long between each lubrification of the bowl bearings ?
thanks in advancemy BBC is ready, this weekend i'll do my first ride of the season.
assuming the bowl seal (around the shaft) holds well around your repaired shaft you should be able to fill it with 90 wt and simply periodically check it
btw not sure what the water distribution will be like given you inbound water plumbing its been my expirience water flow takes the path of least resistance and always best to have hoses equal length and simetrical may tend to run hotter (or colder)
ok thanks,
i will carefully check the shaft.
