Well I started taking my pump apart tonight which is insanely easy since these things are so simple. I took a few pics. The leading edges on the intake side are rounded and beat up but the back side of the impeller looks pretty good from what I can see. What is the proper way to clean up the impeller? Do you only smooth it up and grind from the top side without touching the bottom side of the edge? Here is what the impeller looks like on both sides and also some pics of the stator which looks a bit beat up also. Let me know what you guys think. It looks like it is a B impeller and says aggressor mb401 on it....which doesn't mean a lot to me maybe someone can chime in....its an 18 ft baja with a 402 bbc near stock, with this je pump and has a place diverter, turns 4600 rpm and does only 45-49 mph depending on how many ppl are in it which seems a little slow to me...according to the impeller chart its making 300ish hp. Is this the right size impeller for the boat? and would a loader thats set up right help my boat out any?
Here is the intake side.... I need a bigger wrench to get the impeller nut off so this is the best I could get of this side so far but it looks like it should be fixable
Here is the backside of the impellar, it has nice crisp edges
Here is the inside of the bowl.... does this stator look ok or is there anything to do to clean it up a bit?
I am going out of town for the weekend and I will get a wrench to fit the nut to get it off and I am getting a larger diameter caliper to measure the impeller and wear ring to check clearance, just by moving the shaft by hand it seems like its a little sloppy and not in tolerance which could most certainly be adding to the problem. Ohh and some more info... when u floor it the nose likes to come up and just doesn't seem to get on plane real quick at all even with the diverter trimmed all the way down to start.
Sorry for all the questions but I'm new to these jets and any help or suggestions are appreciated! thanks in advance
LinkBack URL
About LinkBacks
